Linux installation instructions
Standard installation script:
/bin/bash -c "$(curl -fsSL https://api.sdrplay.com/software/install.sh)"
Silent install and accept license agreement:
/bin/bash -c "ACCEPTLICENSE=1 $(curl -fsSL https://api.sdrplay.com/software/install.sh)"
Install on non-Ubuntu LTS releases (do not check for dependencies):
/bin/bash -c "NOTSUPPORTED=1 $(curl -fsSL https://api.sdrplay.com/software/install.sh)"
Install from downloaded files instead of getting the files from the server:
/bin/bash -c "DONOTDOWNLOAD=1 $(curl -fsSL https://api.sdrplay.com/software/install.sh)"
Here are the files you will need to download for the offline install, choose your architecture and download ALL 4 files – after downloading the files you need to run the install script from a terminal window from the same folder that the files have been downloaded to:
x64
https://api.sdrplay.com/software/sdrconnect_linux-x64_d34bf923c.tar.gz
https://api.sdrplay.com/software/sdrconnect_linux-x64_d34bf923c.tar.gz.sha256
https://api.sdrplay.com/software/rigcontrol_linux-x64_74fbbe8.tar.gz
https://api.sdrplay.com/software/rigcontrol_linux-x64_74fbbe8.tar.gz.sha256
arm64
https://api.sdrplay.com/software/sdrconnect_linux-arm64_d34bf923c.tar.gz
https://api.sdrplay.com/software/sdrconnect_linux-arm64_d34bf923c.tar.gz.sha256
https://api.sdrplay.com/software/rigcontrol_linux-arm64_74fbbe8.tar.gz
https://api.sdrplay.com/software/rigcontrol_linux-arm64_74fbbe8.tar.gz.sha256
You can use multiple option variables if needed, e.g.
/bin/bash -c "NOTSUPPORTED=1 ACCEPTLICENSE=1 $(curl -fsSL https://api.sdrplay.com/software/install.sh)"
Translate »
